跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Part# 3805-30529
  1. Remove the six 13 mm case screws with philips #0 screwdriver.
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Use the plastic separating tool to separate the casing halves of the cordless screwdriver. Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing. Using the wire cutters, cut the black and red motor wires where they connect to the motor.
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  5. Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  6. Ensure the new motor terminals are clean before soldering. Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it. Solder the black wire to the other terminal of the motor.
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  7. Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
结论
Tyler Vincent
于2014年02月24日注册
428 信誉积分
创作了4篇指南
团队
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G5
3 名成员
创作了5篇指南
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 7
总计 498
