跳转到主内容
  1. Remove the six 13 mm casing screws with the #0 Phillips screwdriver.
    • Remove the six 13 mm casing screws with the #0 Phillips screwdriver.
  2. Separate the screwdriver casing halves with the plastic opening tool. Separate the screwdriver casing halves with the plastic opening tool.
    • Separate the screwdriver casing halves with the plastic opening tool.
  3. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  4. Slide the bit chuck assembly out from the casing half.
    • Slide the bit chuck assembly out from the casing half.
  5. Apply a dab of grease to the end of the drill motor coupler.
    • Apply a dab of grease to the end of the drill motor coupler.
  6. Insert new bit chuck assembly into the drill casing.
    • Insert new bit chuck assembly into the drill casing.
结论
另外一个人完成了本指南。
Tyler Vincent
于2014年02月24日注册
428 信誉积分
创作了4篇指南
团队
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G5
3 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 328
