跳转到主内容
Durofix RV332 Battery Replacement
你所需要的
  1. Durofix RV332 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Durofix RV332 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Durofix RV332 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: 步骤 2 中的图像 1,2 Durofix RV332 Battery Replacement: 步骤 2 中的图像 2,2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: 步骤 3 中的图像 1,1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
结论
2等其他人完成本指南。
Brennan Wade
于02/21/14注册
122 声望
撰写一个指南
团队
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 2,694
