跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to replace a defective battery LED indicator. A new battery LED is need to complete this repair.
  1. Remove the six 13 mm case screws with a #0 Phillips screwdriver.
    • Remove the six 13 mm case screws with a #0 Phillips screwdriver.
  2. Using a plastic opening tool, separate the casing halves to expose the contents of the cordless screwdriver. Using a plastic opening tool, separate the casing halves to expose the contents of the cordless screwdriver.
    • Using a plastic opening tool, separate the casing halves to expose the contents of the cordless screwdriver.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing. Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board. Remove the LED from the circuit board while the solder is still melted.
    • Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing.
    • Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board.
    • Remove the LED from the circuit board while the solder is still melted.
  5. Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place. Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
    • Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place.
    • Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
结论
Tyler Vincent
于2014年02月24日注册
428 信誉积分
创作了4篇指南
团队
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G5
3 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 691
