跳转到主内容
加入维修社区 - 创建账户
DualShock 4 Controller Rumble Motors Replacement
你所需要的
  1. DualShock 4 Controller Rumble Motors Replacement, Rumble Motors: 步骤 1 中的图像 1,1
    • Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
  2. DualShock 4 Controller Rumble Motors Replacement: 步骤 2 中的图像 1,1
    • Remove the rear plate.
    • We recommend using a metal spudger for this step.
  3. DualShock 4 Controller Rumble Motors Replacement: 步骤 3 中的图像 1,2 DualShock 4 Controller Rumble Motors Replacement: 步骤 3 中的图像 2,2
    • Desolder the joints that attach the rumble motors to the motherboard.
    • For more information on soldering, click here.
  4. DualShock 4 Controller Rumble Motors Replacement: 步骤 4 中的图像 1,2 DualShock 4 Controller Rumble Motors Replacement: 步骤 4 中的图像 2,2
    • There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
    • Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
  5. DualShock 4 Controller Rumble Motors Replacement: 步骤 5 中的图像 1,1
    • Remove the faceplate from the motherboard.
  6. DualShock 4 Controller Rumble Motors Replacement: 步骤 6 中的图像 1,3 DualShock 4 Controller Rumble Motors Replacement: 步骤 6 中的图像 2,3 DualShock 4 Controller Rumble Motors Replacement: 步骤 6 中的图像 3,3
    • With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
结论
13等其他人完成本指南。
3指南评论
I’d recommend adding removal instructions for the touchpad also
AlexMorse - 回复
the rumble packs are stuck with an adhesive on my controller. The best way to remove the rumble pack in this case? thanks
Ka Erd - 回复
I'm most likely way too late, but if there is an adhesive, I would probably use something that breaks glue down and is safe for electronics
Harry Harshman -
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 87
过去 30 天: 377
总计 31,011
