跳转到主内容
加入维修社区 - 创建账户
DualShock 4 CUH-ZCT2 Motherboard Replacement
你所需要的
  1. DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the rear panel screws: 步骤 1 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the rear panel screws: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
    添加评论
  2. DualShock 4 CUH-ZCT2 Motherboard Replacement, Separate the rear panel: 步骤 2 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement, Separate the rear panel: 步骤 2 中的图像 2,2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
    添加评论
  3. DualShock 4 CUH-ZCT2 Motherboard Replacement, Release the plastic clips: 步骤 3 中的图像 1,3 DualShock 4 CUH-ZCT2 Motherboard Replacement, Release the plastic clips: 步骤 3 中的图像 2,3 DualShock 4 CUH-ZCT2 Motherboard Replacement, Release the plastic clips: 步骤 3 中的图像 3,3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
    添加评论
  4. DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the rear panel: 步骤 4 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the rear panel: 步骤 4 中的图像 2,2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
    询问修复机器人
    添加评论
  5. DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 5 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
    添加评论
  6. DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the battery: 步骤 6 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the battery: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
    添加评论
  7. DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 7 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the battery.
    询问修复机器人
    添加评论
  8. DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the motherboard: 步骤 8 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement, Remove the motherboard: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
    添加评论
  9. DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 9 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the battery bracket.
    询问修复机器人
    添加评论
  10. DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 10 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
    添加评论
  11. DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 11 中的图像 1,2 DualShock 4 CUH-ZCT2 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Separate the motherboard and midframe assembly from the front panel.
    添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
Sam Omiotek
于02/25/19注册
98,734 声望
创作了290篇指南
2指南评论
I have followed the steps with an ifixit replacement board, but the controller doesn't stay on after connecting via bluethoot, and the usb connection is not working either, i've checked with the damaged board and all of that is working correctly.
Is there any additional steps to make it work? Did i received a faulty board?
cesar patiño - 回复 分享
Update to this comment, the battery was dead, so as of now, it is just the usb port that doesn't work, but just with the replacement board, it is brand new from ifixit store, so i'm still thinking it is faulty.
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 117
过去 30 天: 504
总计 29,215
