跳转到主内容
DualShock 4 CUH-ZCT1 Charging Port Replacement
你所需要的
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 3 中的图像 1,2 DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 3 中的图像 2,2
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 4 中的图像 1,1
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 7 中的图像 1,2 DualShock 4 CUH-ZCT1 Charging Port Replacement: 步骤 7 中的图像 2,2
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
结论
7等其他人完成本指南。
Andy Lam
于01/31/23注册
307 声望
撰写一个指南
团队
York University, Team P-10, Allen Fall 2022 York University, Team P-10, Allen Fall 2022 的会员
YORK-ALLEN-F22SPG10
1 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 87
过去 30 天: 542
总计 4,092
