跳转到主内容
DualShock 4 CHU-ZCT2U Outer Shell Replacement
你所需要的
  1. DualShock 4 CHU-ZCT2U Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,3 DualShock 4 CHU-ZCT2U Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 2,3 DualShock 4 CHU-ZCT2U Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Outer Shell Replacement: 步骤 2 中的图像 1,3 DualShock 4 CHU-ZCT2U Outer Shell Replacement: 步骤 2 中的图像 2,3 DualShock 4 CHU-ZCT2U Outer Shell Replacement: 步骤 2 中的图像 3,3
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
结论
7等其他人完成本指南。
David Seale
于10/09/17注册
1,630 声望
创作了2篇指南
团队
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G5
3 名成员
创作了22篇指南
一条评论
FYI for anyone looking: re-shelling a v1 controller with v2 innards is possible but incredibly time consuming. My 20th anniversary controller died (v3 circuit board) so I transplanted all parts from a PS-Pro controller. It requires lots of cutting and trimming of the shell to match the inner profile of the newer shell to enable it to close up cleanly. There are no cuts or modifications needed to the V2 controller components however, but the new style light bar need migrating across.
Steve - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,557
