跳转到主内容
DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, Outer Shell: 步骤 1 中的图像 1,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, Outer Shell: 步骤 1 中的图像 2,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
    When re-asembling, be careful to check that all buttons/triggers are moving correctly. They can get misaligned when prying the two shell halves apart.
    Tale Spinner - 回复
    This part is missing vital information on how to correctly pry the case open. In the 3rd picture you can see there is actually damaged/broken clip already. In order to open the case without damage to the plastic clips inside the controller holding the plastics together you need to insert thin piece of metal between the trigger buttons on each side and push the clip outwards before trying to separate the parts, and if done correctly there is no force needed to pry open the controller. There is actually no necessary need for the clips, but if you want to keep your controller in mint condition without voiding the warranty, take care not to break these clips.
    Ville Närhi - 回复
    Your advice for opening shell was so bad and harmful.
    It's not correct
    Kiarash Moallemi - 回复
    And two more tiny clips to the left and right of the headphone & EXT port. They’re VERY delicate, reckless prying WILL break at least ONE of these.
    Strings Cat - 回复
    I've written a guide for how to find and unlatch the clips
    Important Step For Opening the DualShock 4 CUH-ZCT2U
    Richard - 回复
  2. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 2 中的图像 1,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 2 中的图像 2,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 2 中的图像 3,3
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
    If you just want to change the battery, this step is not necessary; it can be done without disconnecting the ribbon cable.
    Tale Spinner - 回复
  3. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, Battery: 步骤 3 中的图像 1,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, Battery: 步骤 3 中的图像 2,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, Battery: 步骤 3 中的图像 3,3
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
    Be extra careful - the power port socket pulled loose from the motherboard for me. I would suggest holding down the socket itself with one tool and gradually loosening the plug from the port.
    tylertemple - 回复
    Hey i have a question. When i plug my usb into the port the yellow color shows and that means its charging right? Because i left it overnight and i for sure know that it was yellow the whole time. But it didnt charge a single bit.
    Help - 回复
  4. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 4 中的图像 1,2 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
    this and the last step arnt necessary you just put the battery back and connect all of it up
    Joe Flores - 回复
  5. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 5 中的图像 1,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 5 中的图像 2,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 5 中的图像 3,3
    • Unhook the battery case from the motherboard, and pull it off.
  6. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, L and R Buttons: 步骤 6 中的图像 1,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, L and R Buttons: 步骤 6 中的图像 2,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement, L and R Buttons: 步骤 6 中的图像 3,3
    • Pull out the second CPU ribbon to separate the inner workings from the top of the outer shell.
  7. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 7 中的图像 1,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 7 中的图像 2,3 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 7 中的图像 3,3
    • Pry the button from the controller using the plastic opening tool. Slide the tool between the buttons. There will be a tab you can push in to remove the button.
    • If too much force is applied, the button could go flying upon separating. Try not to force the buttons too much.
  8. DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 8 中的图像 1,2 DualShock 4 CHU-ZCT2U L1 and R1 Buttons Replacement: 步骤 8 中的图像 2,2
    • Insert the plastic opening tool into the space created when the button is pressed down. Make sure the tool is situated directly in the center of the space, before attempting to pry the button out.
结论
26等其他人完成本指南。
Michelle Joseph
于10/09/17注册
1,762 声望
创作了3篇指南
团队
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G5
3 名成员
创作了22篇指南
4条评论
Is it possible to replace the zct2u triggers with custom 1st gen triggers? It seems like the only major difference is the extra piece on the latest models to prevent losing the trigger.
FTC Gaming - 回复
Does this stops the issue I have that is when I press L2, my character sometimes goes forward, like the L2 would be creating contact with the left directional going forward option.
Erick Xavier - 回复
My controller lost the R1, so I need to buy one to replace it. After pulling apart my controller, I noticed the back of the L1 button looks different (the plastic connection pieces are completely different) than the photos in your directions. Are there different types of shoulder buttons available? Or is it that my controller is a different generation? If so, do you supply the pieces for this controller type?
Corbin - 回复
Hey, can you explain the differences between the V1 and V2 Trigger buttons, they are different. I stepped on the R2 button and it ripped out the R2 button and damaged the housing (my father is the trades guy, obviously).
I don’t know if it’s worth fixing, or if I should just buy a new controller.
Andrew Ahmed - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 83
过去 30 天: 460
总计 36,924
