简介
Follow this guide to replace the joystick covers on a Sony Dualshock 4 CHU-ZCT2U PlayStation controller.
你所需要的
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
Pull the right joystick cover straight off the joystick module to remove it.
26等其他人完成本指南。
