跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver. Pry the two halves of the shell apart using a plastic opening tool. Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers. Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers. Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Unplug the black and red wires from the power port located on the motherboard. Remove the old battery from the controller. Remove the old battery from the controller.
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  5. Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver. Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  6. Unhook the battery case from the motherboard, and pull it off. Unhook the battery case from the motherboard, and pull it off. Unhook the battery case from the motherboard, and pull it off.
    • Unhook the battery case from the motherboard, and pull it off.
结论
12等其他人完成本指南。
Michelle Joseph
于2017年10月09日注册
1,136 信誉积分
创作了3篇指南
团队
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G5
3 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 12
过去的7天: 97
过去的30天: 449
总计 8,059
