简介
这将向您展示如何拆卸Dualshock 4的外壳,以便您可以更换外壳或拆解控制器。
用镊子将带状电缆从主板端口拔出,以完全分开两部分。
If you just want to change the battery, this step is not necessary; it can be done without disconnecting the ribbon cable.
要重新组装设备,请按照相反的顺序执行这些说明。
6等其他人完成本指南。
特别感谢这些译者︰
100%
Kanic正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
一条评论
FYI for anyone looking: re-shelling a v1 controller with v2 innards is possible but incredibly time consuming. My 20th anniversary controller died (v3 circuit board) so I transplanted all parts from a PS-Pro controller. It requires lots of cutting and trimming of the shell to match the inner profile of the newer shell to enable it to close up cleanly. There are no cuts or modifications needed to the V2 controller components however, but the new style light bar need migrating across.
When re-asembling, be careful to check that all buttons/triggers are moving correctly. They can get misaligned when prying the two shell halves apart.
Tale Spinner - 回复
This part is missing vital information on how to correctly pry the case open. In the 3rd picture you can see there is actually damaged/broken clip already. In order to open the case without damage to the plastic clips inside the controller holding the plastics together you need to insert thin piece of metal between the trigger buttons on each side and push the clip outwards before trying to separate the parts, and if done correctly there is no force needed to pry open the controller. There is actually no necessary need for the clips, but if you want to keep your controller in mint condition without voiding the warranty, take care not to break these clips.
Ville Närhi - 回复
Your advice for opening shell was so bad and harmful.
It's not correct
Kiarash Moallemi - 回复
And two more tiny clips to the left and right of the headphone & EXT port. They’re VERY delicate, reckless prying WILL break at least ONE of these.
Strings Cat - 回复
