此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
使用本指南更换 DualShock 3 控制器上模制的模拟摇杆帽。电子摇杆焊接在控制器主板上。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
101等其他人完成本指南。
由衷感谢以下译者:
100%
playstationcentral82正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4指南评论
Reassembly doesn’t quite follow these steps in reverse order. Proper reassembly with the shoulder buttons is tricky. However, its much more simple to omit resinstalling the ‘1’ buttons until the controller housing is completely reassembled. They have one-way snapping clips on the edges, and appear designed to installed this way. Also, it’s good to double check the internal ‘1’ button switches are correctly centered inside the controller housing before4 snap in the ‘1’ buttons.
Thanks Andrew, your guide worked like a charm. My roomie spilled soda on the controller and the buttons were sticky. Cleaned it all up and all is good. As an aside, this controller had a rattle inside from new. I found a little black piece of plastic that looks like a bridge of sort. Now the rattle is gone too.
Ma manette ps3 vibrait avant mais j'ai un problème avec les boutons R1 et L1 donc j'ai démonter pour voir ce qui n'allait pas mais dès lors elle a arrêtée de vibrer
