跳转到主内容
DualSense Controller V2 Stick Drift Fix
你所需要的
  1. DualSense Controller V2 Stick Drift Fix, DualSense Controller V2 Stick Drift Fix: 步骤 1 中的图像 1,1
    • This controller is the black version, but this guide applies to every CFI-ZCT1W model.
    • Here is a video demonstrating how bad the controller stick drift was before the fix.
  2. DualSense Controller V2 Stick Drift Fix: 步骤 3 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 3 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 3 中的图像 3,3
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the right bottom of the controller and pry it up to release the clips that secure it.
  3. DualSense Controller V2 Stick Drift Fix: 步骤 4 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 4 中的图像 2,2
    • Slide a pick along the lower-right edge to release the clips securing it to the case.
  4. DualSense Controller V2 Stick Drift Fix: 步骤 5 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 5 中的图像 2,2
    • Slide a pick along the lower-left edge to release the clips.
  5. DualSense Controller V2 Stick Drift Fix: 步骤 6 中的图像 1,1
    • This is how the controller looks when all the clips are released.
  6. DualSense Controller V2 Stick Drift Fix: 步骤 7 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 7 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 7 中的图像 3,3
    • Use your fingers to lift up the bottom edge of the middle trim.
    • Watch out for the two pieces that are hidden underneath the touchpad.
  7. DualSense Controller V2 Stick Drift Fix: 步骤 8 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 8 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 8 中的图像 3,3
    • Insert the flat end of a spudger into the gap between L1 and L2.
    • Pry upward against L1 to remove the L1 button.
  8. DualSense Controller V2 Stick Drift Fix: 步骤 9 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 9 中的图像 2,2
    • Insert the flat end of a spudger into the gap between R1 and R2.
    • Pry upward against the R1 to remove the R1 button.
  9. DualSense Controller V2 Stick Drift Fix: 步骤 10 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 10 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons, as well as the two 6.4 mm screws that secure the bottom corners of the lower case.
    • You will have a total of four 6.4 mm Phillips screws. Make sure not to lose any of them.
  10. DualSense Controller V2 Stick Drift Fix: 步骤 11 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 11 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 11 中的图像 3,3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller V2 Stick Drift Fix: 步骤 12 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 12 中的图像 2,2
    • Slide the spudger along the edge to release the clips that secure the rear case.
    • Top clips (near the triggers) are stiffer than the others and might require more force and prying to release.
  12. DualSense Controller V2 Stick Drift Fix: 步骤 13 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 13 中的图像 2,2
    • Same as the other side, slide the spudger along the edge to release the clips that secure the rear case.
  13. DualSense Controller V2 Stick Drift Fix: 步骤 14 中的图像 1,1
    • Remove the rear case.
  14. DualSense Controller V2 Stick Drift Fix: 步骤 15 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 15 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 15 中的图像 3,3
    • Use tweezers or your fingers to disconnect the battery from the motherboard.
    • To prevent damaging the wire, grip the white connector, not the wires.
  15. DualSense Controller V2 Stick Drift Fix: 步骤 16 中的图像 1,1
    • Use tweezers to disconnect the upper and lower microphone cables.
    • Use the pull tabs to disconnect the cables. Don't pull on the cables themselves.
  16. DualSense Controller V2 Stick Drift Fix: 步骤 17 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 17 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 17 中的图像 3,3
    • Use a Phillips screwdriver to remove the single 6.4 mm screw that secures the battery bracket.
    • Remove the battery bracket.
    • At this point, you will have a total of five 6.4 mm Phillips screws.
  17. DualSense Controller V2 Stick Drift Fix: 步骤 18 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 18 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 18 中的图像 3,3
    • Use a pair of tweezers to grip the touchpad ribbon cable, and pull it out of the motherboard.
  18. DualSense Controller V2 Stick Drift Fix: 步骤 19 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 19 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 19 中的图像 3,3
    • Use a pair of tweezers to disconnect the right trigger ribbon cable.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
  19. DualSense Controller V2 Stick Drift Fix: 步骤 20 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 20 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 20 中的图像 3,3
    • Use a pair of tweezers to disconnect the left trigger ribbon cable from the motherboard.
  20. DualSense Controller V2 Stick Drift Fix: 步骤 21 中的图像 1,1
    • Make sure you have disconnected the four ribbon cables from the motherboard before moving on to the next step.
  21. DualSense Controller V2 Stick Drift Fix: 步骤 22 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 22 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 22 中的图像 3,3
    • Gently push the joysticks to separate the motherboard from the case.
    • The motherboard and the case are still connected through 4 soldered wires. Take care not to strain them.
  22. DualSense Controller V2 Stick Drift Fix: 步骤 23 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 23 中的图像 2,2
    • Use your fingers to pull the joystick covers straight up and off.
  23. DualSense Controller V2 Stick Drift Fix: 步骤 24 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 24 中的图像 2,2
    • Use a spudger to pry the drifting joystick potentiometer slots open.
    • Pry open the potentiometer slot gently or you will damage the slot.
  24. DualSense Controller V2 Stick Drift Fix: 步骤 25 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 25 中的图像 2,2
    • Use tweezers to remove the wiper.
    • Try to keep the slots down to about only 60o. Completely prying it open will damage the slots and they will not be able to close.
  25. DualSense Controller V2 Stick Drift Fix: 步骤 26 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 26 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 26 中的图像 3,3
    • Repeat the previous step for the other potentiometer.
  26. DualSense Controller V2 Stick Drift Fix: 步骤 27 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 27 中的图像 2,2
    • Use a pair of tweezers to remove the wiper.
  27. DualSense Controller V2 Stick Drift Fix: 步骤 28 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 28 中的图像 2,2
    • Dampen a cotton swab with high-concentration isopropyl alcohol.
    • Flip the wiper to the other side and use the damp cotton swab to rub off any gunk or grease.
    • Repeat this step for the other wiper.
  28. DualSense Controller V2 Stick Drift Fix: 步骤 29 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 29 中的图像 2,2
    • Use a cotton swab damp with high-concentration isopropyl alcohol to clean the inside of both of the potentiometer slots.
  29. DualSense Controller V2 Stick Drift Fix: 步骤 30 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 30 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 30 中的图像 3,3
    • Put the cleaned wipers back into their respective potentiometer slots.
    • When reinstalling the wiper, make sure the curved prongs is at the top.
  30. DualSense Controller V2 Stick Drift Fix: 步骤 31 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 31 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 31 中的图像 3,3
    • The remainder of the guide details reassembly.
    • Use your finger to push and close each slot.
    • Make sure you hear a "click" when you close it.
  31. DualSense Controller V2 Stick Drift Fix: 步骤 32 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 32 中的图像 2,2
    • Reinstall the joystick covers.
  32. DualSense Controller V2 Stick Drift Fix: 步骤 33 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 33 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 33 中的图像 3,3
    • Put the motherboard back into the case.
    • Make sure the four highlighted cables are on top of the motherboard.
  33. DualSense Controller V2 Stick Drift Fix: 步骤 34 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 34 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 34 中的图像 3,3
    • Use tweezers to insert the touchpad cable into its socket.
    • Use your finger to fully seat the cable.
    • Push gently to prevent breaking the ribbon cable.
  34. DualSense Controller V2 Stick Drift Fix: 步骤 35 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 35 中的图像 2,2
    • Use tweezers to put the trigger cable in the slot, then place the tweezer on the top sides of the cable and push it down until it's fully reseated.
  35. DualSense Controller V2 Stick Drift Fix: 步骤 36 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 36 中的图像 2,2
    • Use tweezers to put the other trigger cable in the slot, then place the tweezers on top of the cable and push it down until it's fully reseated.
  36. DualSense Controller V2 Stick Drift Fix: 步骤 37 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 37 中的图像 2,2
    • Use a pair of tweezer to insert the lower microphone cable the cable into its slot.
    • Push the cable down until it's fully reseated.
  37. DualSense Controller V2 Stick Drift Fix: 步骤 38 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 38 中的图像 2,2
    • Use a Phillips screwdriver to reinstall the 6.4 mm screw that secures the battery bracket.
  38. DualSense Controller V2 Stick Drift Fix: 步骤 39 中的图像 1,1
    • Insert the upper microphone cable into its socket.
  39. DualSense Controller V2 Stick Drift Fix: 步骤 40 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 40 中的图像 2,2
    • Plug in the battery cable.
  40. DualSense Controller V2 Stick Drift Fix: 步骤 41 中的图像 1,3 DualSense Controller V2 Stick Drift Fix: 步骤 41 中的图像 2,3 DualSense Controller V2 Stick Drift Fix: 步骤 41 中的图像 3,3
    • Assemble the rear case.
  41. DualSense Controller V2 Stick Drift Fix: 步骤 42 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 42 中的图像 2,2
    • Use a Phillips screwdriver to install the two 6.4 mm screws behind the L1 and R1 buttons, as well as the two 6.4 mm screws that secure the bottom corners of the lower case.
  42. DualSense Controller V2 Stick Drift Fix: 步骤 43 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 43 中的图像 2,2
    • Put the L1 button cover back in.
    • Press it down and until you hear a "click."
  43. DualSense Controller V2 Stick Drift Fix: 步骤 44 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 44 中的图像 2,2
    • Put the R1 button cover back in.
  44. DualSense Controller V2 Stick Drift Fix: 步骤 45 中的图像 1,2 DualSense Controller V2 Stick Drift Fix: 步骤 45 中的图像 2,2
    • Reinstall the middle trim.
    • These two highlighted pieces need to go under the touchpad.
    • Here's the testing again; see the difference?
结论
If you are still having problems after following all the steps in this guide, your controller probably has another issue.
Please check out other iFixit repair guides, such as replacing the entire Joystick.
Hope you find this guide helpful and may your controllers last forever!
23等其他人完成本指南。
Alvin2325
于03/20/24注册
1,221 声望
撰写一个指南
团队
Engl2030AS Engl2030AS 的会员
Community
1 名成员
创作了5篇指南
11指南评论
Great pictures, great descriptions, and a finish that wasn’t just “do everything in reverse.” Can’t ask for anything more.
Jay Gagnon - 回复
Perfect. Thank you for your time and effort on this. I just followed this successfully for the third time now. Saving so many “busted” controllers
Ryan - 回复
Had everything on hand except a steady hand lol. After much persistence and muttered oaths I succeeded. Ifixit is the goat. Ps small intricate parts required small intricate hands hence the oaths and persistence.
Benjamin Roman - 回复
Ok the guide is good and the process works well. However I ran into a new problem following this - my right stick cannot register as being fully pushed to the left or right. In games where this controls the camera, the camera is a little slower as a result of this. Specifically in Fallout 76, in VATS you use the right stick at it's FULL left or right in order to switch between targeted areas - I can now not do that. Of course, plugging in another controller that is known to work and these issues go away. Using software to correct the sensitivity of the left and right axis of this stick corrects the speed at which the camera pan behaves, however it does not work to allow the VATS targetting.
Can anyone weigh in on what I should be looking at around the joystick potentiometer slots that could cause this? Could perhaps a very fine hair cause this issue or is it indicative of something more serious that may not be fixable by the average user?
Jeremy Kelly - 回复
Would the iFixit Precision Cleaning Kit work for this job?
originalhawk - 回复
添加评论
浏览统计数据:
过去 24 小时: 227
过去 7 天: 1,089
过去 30 天: 5,021
总计 72,206
