跳转到主内容
Drum Head Replacement
你所需要的
  1. Drum Head Replacement, Drum Head: 步骤 1 中的图像 1,1
    • Loosen the tension rods until all rods are free from the drum.
    • The tension rods are universal for all drums and drum sets.
  2. Drum Head Replacement: 步骤 2 中的图像 1,1
    • Remove the rim and drum head.
    • Keep track of the tension rods by leaving them in their holders on the rim.
  3. Drum Head Replacement: 步骤 3 中的图像 1,1
    • Put on the new drum head first.
    • Put the rim on, making sure that the tension rods are properly aligned.
  4. Drum Head Replacement: 步骤 4 中的图像 1,1
    • Tighten the tension rods with your fingers until you begin to feel tension.
    • You do not want them completely tightened yet. You just want to make sure the head is not wrinkled.
  5. Drum Head Replacement: 步骤 5 中的图像 1,3 Drum Head Replacement: 步骤 5 中的图像 2,3 Drum Head Replacement: 步骤 5 中的图像 3,3
    • Begin to tighten the tension rods in a star pattern using a drum key.
    • Do not tighten the tension rods in a clockwise or counter clockwise pattern.
    • Tighten the rods until you find the sound you want from the drum.
  6. Drum Head Replacement: 步骤 6 中的图像 1,1
    • While tightening the tension rods, tap a drumstick on the drum head about an inch from the tension rods.
    • This is how you will determine which tension rods need to be tightened, loosened, or left alone.
  7. Drum Head Replacement: 步骤 7 中的图像 1,3 Drum Head Replacement: 步骤 7 中的图像 2,3 Drum Head Replacement: 步骤 7 中的图像 3,3
    • Once you have found the sound you like and the drum is in tune, push around the middle of the drum head, moving around the drum.
    • Repeat Steps 6 and 7 until the drum is in tune again.
结论
Daniel Barry
于11/28/21注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 191
