跳转到主内容
加入维修社区 - 创建账户
Droid Ultra XT1080 Screen Replacement
你所需要的
  1. Droid Ultra XT1080 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Droid Ultra XT1080 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Droid Ultra XT1080 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Gently remove SIM card tray from device using a metal spudger.
  2. Droid Ultra XT1080 Screen Replacement: 步骤 2 中的图像 1,1
    • After SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your way around the device until all the clips are undone.
    • Be gentle with the plastic to make sure it doesn't crack or break.
  3. Droid Ultra XT1080 Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Screen Replacement: 步骤 4 中的图像 1,2 Droid Ultra XT1080 Screen Replacement: 步骤 4 中的图像 2,2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Screen Replacement: 步骤 5 中的图像 1,2 Droid Ultra XT1080 Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Screen Replacement: 步骤 6 中的图像 1,1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Screen Replacement: 步骤 7 中的图像 1,2 Droid Ultra XT1080 Screen Replacement: 步骤 7 中的图像 2,2
    • Once motherboard is removed you have successfully removed the screen from the device.
结论
knoyes
于10/30/18注册
785 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G8
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 11
过去 30 天: 22
总计 934
