跳转到主内容
Droid Ultra XT1080 Battery Replacement
你所需要的
  1. Droid Ultra XT1080 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: 步骤 2 中的图像 1,1
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: 步骤 4 中的图像 1,2 Droid Ultra XT1080 Battery Replacement: 步骤 4 中的图像 2,2
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: 步骤 5 中的图像 1,1
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: 步骤 7 中的图像 1,2 Droid Ultra XT1080 Battery Replacement: 步骤 7 中的图像 2,2
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: 步骤 8 中的图像 1,1
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
结论
3等其他人完成本指南。
knoyes
于10/30/18注册
785 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G8
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 2,988
