跳转到主内容
Droid MAXX 2 Screen Assembly Replacement
你所需要的
  1. Droid MAXX 2 Screen Assembly  Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Droid MAXX 2 Screen Assembly  Replacement: 步骤 2 中的图像 1,1
    • Pull the sim card tray up out of the phone
  3. Droid MAXX 2 Screen Assembly  Replacement: 步骤 3 中的图像 1,2 Droid MAXX 2 Screen Assembly  Replacement: 步骤 3 中的图像 2,2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Droid MAXX 2 Screen Assembly  Replacement: 步骤 4 中的图像 1,1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Droid MAXX 2 Screen Assembly  Replacement: 步骤 5 中的图像 1,1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Droid MAXX 2 Screen Assembly  Replacement: 步骤 6 中的图像 1,3 Droid MAXX 2 Screen Assembly  Replacement: 步骤 6 中的图像 2,3 Droid MAXX 2 Screen Assembly  Replacement: 步骤 6 中的图像 3,3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Droid MAXX 2 Screen Assembly  Replacement: 步骤 7 中的图像 1,1
    • Remove the disconnected battery from the phone.
  8. Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: 步骤 8 中的图像 1,2 Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: 步骤 8 中的图像 2,2
    • We will be removing these 3 ribbon cables.
    • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • Use tweezers to lift up on the grey latch on the ZIF connector.
    • Remove the ribbon cable from the ZIF connector.
  9. Droid MAXX 2 Screen Assembly  Replacement: 步骤 9 中的图像 1,2 Droid MAXX 2 Screen Assembly  Replacement: 步骤 9 中的图像 2,2
    • Use a pair of tweezers to lift up the black latch on the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  10. Droid MAXX 2 Screen Assembly  Replacement: 步骤 10 中的图像 1,3 Droid MAXX 2 Screen Assembly  Replacement: 步骤 10 中的图像 2,3 Droid MAXX 2 Screen Assembly  Replacement: 步骤 10 中的图像 3,3
    • Using a metal spudger, work your way around the perimeter of the main board and screen.
    • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
结论
2等其他人完成本指南。
Burke Seggerman
于03/18/18注册
704 声望
创作了5篇指南
团队
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 的会员
BU-WILLIAMS-S18S3G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,007
