跳转到主内容
Drill Master Heat Gun Power Cord Replacement
你所需要的
  1. Drill Master Heat Gun Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Cord Replacement: 步骤 3 中的图像 1,3 Drill Master Heat Gun Power Cord Replacement: 步骤 3 中的图像 2,3 Drill Master Heat Gun Power Cord Replacement: 步骤 3 中的图像 3,3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Cord Replacement: 步骤 4 中的图像 1,1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Cord Replacement: 步骤 5 中的图像 1,1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Cord Replacement: 步骤 6 中的图像 1,1
    • Disconnect the power cord wiring from the wire connector.
  7. Drill Master Heat Gun Power Cord Replacement: 步骤 7 中的图像 1,1
    • Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
  8. Drill Master Heat Gun Power Cord Replacement: 步骤 8 中的图像 1,1
    • Remove the power cord from the heat gun.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 653
