跳转到主内容
Drill Master Heat Gun Motor Replacement
你所需要的
  1. Drill Master Heat Gun Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Motor Replacement: 步骤 3 中的图像 1,3 Drill Master Heat Gun Motor Replacement: 步骤 3 中的图像 2,3 Drill Master Heat Gun Motor Replacement: 步骤 3 中的图像 3,3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the metal casing and fan cover from the fan unit.
  6. Drill Master Heat Gun Motor Replacement: 步骤 6 中的图像 1,1
    • Bend the metal prongs backward that connect the fan motor to the plastic cap.
    • Bending the brackets too far back can cause the brackets to break.
  7. Drill Master Heat Gun Motor Replacement: 步骤 7 中的图像 1,1
    • Remove the plastic cap from the motor,
    • This will allow you to work only with the motor and fan.
  8. Drill Master Heat Gun Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the fan by pulling it from the motor rod.
  9. Drill Master Heat Gun Motor Replacement: 步骤 9 中的图像 1,1
    • Remove the two 12mm screws from the plastic fan casing using PH#00
  10. Drill Master Heat Gun Motor Replacement: 步骤 10 中的图像 1,1
    • Remove the plastic fan casing.
  11. Drill Master Heat Gun Motor Replacement: 步骤 11 中的图像 1,1
    • Remove the metal casing from the motor and insert the new motor in its place.
    • You may have to tug a little.
结论
另外一个人完成了本指南。
一条评论
Where can I find a new motor?
jstabler38 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 23
总计 1,515
