简介
If you're confident in your repair skills, use this guide to replace the heating coil in the heart of your heat gun.
你所需要的
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Use the angled tweezers to remove the heating coil end from the input point.
2等其他人完成本指南。
3条评论
Where are the heating coil wires found?
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
