跳转到主内容
Drift HD 720 Speaker Replacement
你所需要的
  1. Drift HD 720 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Drift HD 720 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Speaker Replacement: 步骤 2 中的图像 1,1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the back case from the camera body.
  5. Drift HD 720 Speaker Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the wires connecting the speaker to the motherboard from the motherboard, and solder the wires connecting the new speaker to the motherboard in the same locations as the wires that were removed.
结论
团队
Baylor, Team 10-16, Williams Fall 2015 Baylor, Team 10-16, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G16
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 206
