跳转到主内容
Drift HD 720 Microphone Replacement
你所需要的
  1. Drift HD 720 Microphone Replacement, Battery: 步骤 1 中的图像 1,2 Drift HD 720 Microphone Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Microphone Replacement: 步骤 2 中的图像 1,1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Microphone Replacement, Microphone: 步骤 3 中的图像 1,1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Microphone Replacement: 步骤 4 中的图像 1,1
    • Remove the back case from the camera body.
  5. Drift HD 720 Microphone Replacement: 步骤 5 中的图像 1,1
    • Remove the battery housing from the camera body.
  6. Drift HD 720 Microphone Replacement: 步骤 6 中的图像 1,1
    • Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
结论
团队
Baylor, Team 10-16, Williams Fall 2015 Baylor, Team 10-16, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G16
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 364
