简介
If your videos are not recording sound, replacing the microphone will likely fix this.
你所需要的
Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
即将完成!
结论
