跳转到主内容
Drift HD 720 LCD Screen Replacement
你所需要的
  1. Drift HD 720 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Drift HD 720 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the back case from camera body.
  5. Drift HD 720 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Use J0 Phillips head to remove two 6mm long Phillips head screws from the motherboard.
  7. Drift HD 720 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the motherboard (green) from the front case housing.
  8. Drift HD 720 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Use the J0 Phillips head screws to remove two 5mm long Phillips head screws from the plastic bracket holding LCD in place.
  9. Drift HD 720 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the LCD screen from the front cover.
  10. Drift HD 720 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Slide the black bar toward the LCD screen in order to remove the screen from slot.
  11. Drift HD 720 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the LCD from motherboard.
结论
另外一个人完成了本指南。
团队
Baylor, Team 10-16, Williams Fall 2015 Baylor, Team 10-16, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G16
3 名成员
创作了8篇指南
4指南评论
Did you now where to find the replacement LCD screen? Thanks.
Rodrigo Forrequi - 回复
I believe eBay should work.
Ruru Idahosa - 回复
need a ribbon for stealth 2 any ideas?
dennis - 回复
Good job! That guide indeed helped me a lot to give my Drift HD a good cleaning. Was a bit tough to remove the PCB, but after some fiddling it worked. Should be mentioned that you can remove the microphone from the surrounding rubber gasket so you can wash the gasket with ordinary soap. You can also separate the two PCBs (they are just stacked ontop of earch other using press-fit connectors)for easier access, e. g. if you want to clean and re-grease the collar of the lens unit. Also keep an eye on the aluminum cooler star. It has some heat conduction compond on it that you want to spread evenly. Don't wash it off entirely!
Volker Bartheld - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,292
