跳转到主内容
Dress Shirt Button Replacement
你所需要的
  1. Dress Shirt Button Replacement, Button: 步骤 1 中的图像 1,2 Dress Shirt Button Replacement, Button: 步骤 1 中的图像 2,2
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: 步骤 2 中的图像 1,3 Dress Shirt Button Replacement: 步骤 2 中的图像 2,3 Dress Shirt Button Replacement: 步骤 2 中的图像 3,3
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: 步骤 3 中的图像 1,2 Dress Shirt Button Replacement: 步骤 3 中的图像 2,2
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: 步骤 4 中的图像 1,3 Dress Shirt Button Replacement: 步骤 4 中的图像 2,3 Dress Shirt Button Replacement: 步骤 4 中的图像 3,3
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: 步骤 5 中的图像 1,1
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: 步骤 6 中的图像 1,3 Dress Shirt Button Replacement: 步骤 6 中的图像 2,3 Dress Shirt Button Replacement: 步骤 6 中的图像 3,3
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: 步骤 7 中的图像 1,3 Dress Shirt Button Replacement: 步骤 7 中的图像 2,3 Dress Shirt Button Replacement: 步骤 7 中的图像 3,3
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
结论
Your shirt is now ready to be worn again.
另外一个人完成了本指南。
Jonathan Wong
于04/09/15注册
198 声望
撰写一个指南
团队
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 的会员
CPSU-GREEN-S15S28G4
6 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 27
总计 3,712
