跳转到主内容
Dremel 8220 Gear Lock Button Replacement
你所需要的
  1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: 步骤 1 中的图像 1,1
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
  2. Dremel 8220 Gear Lock Button Replacement: 步骤 2 中的图像 1,1
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
  3. Dremel 8220 Gear Lock Button Replacement: 步骤 3 中的图像 1,1
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
  4. Dremel 8220 Gear Lock Button Replacement: 步骤 4 中的图像 1,1
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
  5. Dremel 8220 Gear Lock Button Replacement: 步骤 5 中的图像 1,3 Dremel 8220 Gear Lock Button Replacement: 步骤 5 中的图像 2,3 Dremel 8220 Gear Lock Button Replacement: 步骤 5 中的图像 3,3
    • Remove the 5 torx screws using a t9 screwdriver head.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
  6. Dremel 8220 Gear Lock Button Replacement: 步骤 6 中的图像 1,1
    • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
结论
connor anisko
于03/09/16注册
300 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G8
3 名成员
创作了5篇指南
3条评论
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - 回复
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Robert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 721
