跳转到主内容
加入维修社区 - 创建账户
Dremel 8200 Disassembly
你所需要的
  1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: 步骤 1 中的图像 1,2 Dremel 8200 Disassembly, Dremel 8200 Disassembly: 步骤 1 中的图像 2,2
    • Take off the screw cap at the top
  2. Dremel 8200 Disassembly: 步骤 2 中的图像 1,2 Dremel 8200 Disassembly: 步骤 2 中的图像 2,2
    • Take out the battery
    • Remove oblong belt clip
  3. Dremel 8200 Disassembly: 步骤 4 中的图像 1,1
    • Unscrew screws
    • Take back u clip out carefully
    • Be very careful to not injure yourself
  4. Dremel 8200 Disassembly: 步骤 6 中的图像 1,2 Dremel 8200 Disassembly: 步骤 6 中的图像 2,2
    • The casing should just open right up and be easily accessible
  5. Dremel 8200 Disassembly: 步骤 7 中的图像 1,1
    • You can remove the buttons except for the sliding one that adjusts the speed
  6. Dremel 8200 Disassembly: 步骤 8 中的图像 1,2 Dremel 8200 Disassembly: 步骤 8 中的图像 2,2
    • You can take the motor out first and it will be a little hard to do so
    • Work your way down and take out each successive circuit board
    • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
结论
3等其他人完成本指南。
2指南评论
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - 回复
How do you replace just the bearing in this assembly?
Andre Da Silva - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 58
总计 4,553
