跳转到主内容
Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement
你所需要的
  1. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: 步骤 2 中的图像 1,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: 步骤 2 中的图像 2,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: 步骤 2 中的图像 3,3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 步骤 3 中的图像 1,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 步骤 3 中的图像 2,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 步骤 3 中的图像 3,3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 步骤 4 中的图像 1,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 步骤 4 中的图像 2,3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 步骤 4 中的图像 3,3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
结论
3等其他人完成本指南。
Michael Smith
于02/10/16注册
175 声望
撰写一个指南
团队
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S3G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 28
总计 3,113
