跳转到主内容
Dremel 7300 MiniMite Cordless Collet Replacement
你所需要的
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 步骤 1 中的图像 1,3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 步骤 1 中的图像 2,3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 步骤 1 中的图像 3,3
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: 步骤 2 中的图像 1,3 Dremel 7300 MiniMite Cordless Collet Replacement: 步骤 2 中的图像 2,3 Dremel 7300 MiniMite Cordless Collet Replacement: 步骤 2 中的图像 3,3
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
结论
7等其他人完成本指南。
Kat
于02/10/16注册
840 声望
创作了3篇指南
团队
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S3G4
4 名成员
创作了4篇指南
2条评论
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - 回复
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 32,537
