跳转到主内容
Dremel 4000 Shaft Lock Pin Replacement
你所需要的
  1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: 步骤 1 中的图像 1,2 Dremel 4000 Shaft Lock Pin Replacement, Back Case: 步骤 1 中的图像 2,2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Shaft Lock Pin Replacement: 步骤 2 中的图像 1,1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Shaft Lock Pin Replacement: 步骤 3 中的图像 1,2 Dremel 4000 Shaft Lock Pin Replacement: 步骤 3 中的图像 2,2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Shaft Lock Pin Replacement: 步骤 4 中的图像 1,1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Shaft Lock Pin Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Shaft Lock Pin Replacement: 步骤 6 中的图像 1,1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: 步骤 7 中的图像 1,1
    • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
    • Remove the damaged shaft lock pin and spring by hand.
    • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
结论
2等其他人完成本指南。
John Cobb
于01/20/16注册
1,719 声望
创作了4篇指南
团队
USF Tampa, Team 15-4, Remmell Spring 2016 USF Tampa, Team 15-4, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G4
4 名成员
创作了13篇指南
2条评论
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - 回复
three years later and I came to the same conclusion: DUH
Randy Martin -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 139
总计 12,383
