跳转到主内容
Dremel 4000 Power Cord Replacement
你所需要的
  1. Dremel 4000 Power Cord Replacement, Back Case: 步骤 1 中的图像 1,2 Dremel 4000 Power Cord Replacement, Back Case: 步骤 1 中的图像 2,2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Power Cord Replacement: 步骤 3 中的图像 1,2 Dremel 4000 Power Cord Replacement: 步骤 3 中的图像 2,2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Power Cord Replacement: 步骤 4 中的图像 1,1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Power Cord Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Power Cord Replacement: 步骤 6 中的图像 1,1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Power Cord Replacement, Power Cord: 步骤 7 中的图像 1,2 Dremel 4000 Power Cord Replacement, Power Cord: 步骤 7 中的图像 2,2
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Dremel 4000 Power Cord Replacement: 步骤 8 中的图像 1,1
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Dremel 4000 Power Cord Replacement: 步骤 9 中的图像 1,1
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
  10. Dremel 4000 Power Cord Replacement: 步骤 10 中的图像 1,1
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
结论
5等其他人完成本指南。
John Cobb
于01/20/16注册
1,719 声望
创作了4篇指南
团队
USF Tampa, Team 15-4, Remmell Spring 2016 USF Tampa, Team 15-4, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G4
4 名成员
创作了13篇指南
一条评论
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 36
总计 5,821
