跳转到主内容
Dreamer Autoshade Idle Tube Length Adjustment
  1. Dreamer Autoshade Idle Tube Length Adjustment, Mark tube: 步骤 1 中的图像 1,2 Dreamer Autoshade Idle Tube Length Adjustment, Mark tube: 步骤 1 中的图像 2,2
    • Before adjusting the size of your tube, make sure you try adjusting the left side mounting nub. This guide is meant for users whose idle tubes are too long to fit after attempting to fit with the left-hand nub adjusted.
    • Measure the amount needed to remove in order to fit the shade in the wall mounts.
    • Measure and mark the distance needed to remove. Repeat this process to draw a circle around the entire tube.
  2. Dreamer Autoshade Idle Tube Length Adjustment, Shorten tube: 步骤 2 中的图像 1,1
    • Use a sander, hacksaw, or appropriate metal cutoff saw to shorten the tube to the desired length. Be sure to use the required safety procedures for your chosen method.
  3. Dreamer Autoshade Idle Tube Length Adjustment, Replace left bearing cap: 步骤 3 中的图像 1,1
    • Replace the bearing cap and nub on the left side of the shade tube.
结论
David
于11/11/20注册
734 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 203
