跳转到主内容
Dreamer Autoshade Driver Blocking
你所需要的
  1. Dreamer Autoshade Driver Blocking, Remove motor hub fasteners: 步骤 1 中的图像 1,2 Dreamer Autoshade Driver Blocking, Remove motor hub fasteners: 步骤 1 中的图像 2,2
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
  2. Dreamer Autoshade Driver Blocking, Remove driver bearing cap: 步骤 2 中的图像 1,2 Dreamer Autoshade Driver Blocking, Remove driver bearing cap: 步骤 2 中的图像 2,2
    • Using a flathead screwdriver, pry the bearing cap from the tube.
  3. Dreamer Autoshade Driver Blocking, Loosen PCB mounting Screws: 步骤 3 中的图像 1,3 Dreamer Autoshade Driver Blocking, Loosen PCB mounting Screws: 步骤 3 中的图像 2,3 Dreamer Autoshade Driver Blocking, Loosen PCB mounting Screws: 步骤 3 中的图像 3,3
    • Use a #1 Phillips head screwdriver to loosen the PCB mounting screws until the circuit board can be adjusted. This should only take 1-2 full rotations of the screwdriver. Do not fully remove the screws.
  4. Dreamer Autoshade Driver Blocking, Straighten PCB: 步骤 4 中的图像 1,1
    • The circuit board can cause problems if it is not properly centered on the sheet metal mount. See the picture for details.
    • The blue lines in the picture show the edges of the white metal PCB plate, while the red lines show the edge of the PCB. Adjust the PCB so it lines up as closely as possible with the metal plate. This will ensure that the PCB does not contact the edge of the tube while rotating.
  5. Dreamer Autoshade Driver Blocking, Tighten PCB mounting screws: 步骤 5 中的图像 1,1
    • Tighten the two PCB mounting screws until the PCB cannot move freely.
结论
David
于11/11/20注册
734 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 289
