跳转到主内容
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: 步骤 1 中的图像 1,3 Draining a Toilet Tank, Tank Lid: 步骤 1 中的图像 2,3 Draining a Toilet Tank, Tank Lid: 步骤 1 中的图像 3,3
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: 步骤 2 中的图像 1,2 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: 步骤 2 中的图像 2,2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: 步骤 3 中的图像 1,2 Draining a Toilet Tank, Draining a Toilet Tank: 步骤 3 中的图像 2,2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
结论
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
另外一个人完成了本指南。
Ron Davis
于02/17/15注册
31,192 声望
创作了13篇指南
2条评论
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - 回复
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 70
过去 30 天: 212
总计 32,253
