跳转到主内容
Dragon Touch MID 7138 Motherboard Replacement
你所需要的
  1. Dragon Touch MID 7138 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
    • Wedge around all edges until the back cover pops off entirely.
  2. Dragon Touch MID 7138 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Gently pry the back cover from the screen using your hands.
  3. Dragon Touch MID 7138 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Remove tape covering wire joints
    • Remove (3) 2.5mm screws using a PH001 screw driver.
    • The screws locations are highlighted in the image to the left.
  4. Dragon Touch MID 7138 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
  5. Dragon Touch MID 7138 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Similar to previous step, pull the large U2 ribbon gentle out of its port.
  6. Dragon Touch MID 7138 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
  7. Dragon Touch MID 7138 Motherboard Replacement: 步骤 7 中的图像 1,2 Dragon Touch MID 7138 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Desolder the wires attached to the mother board with a soldering iron.
    • Then pull the wires from the joints.
结论
Trevor Farkas
于01/26/17注册
101 声望
撰写一个指南
团队
IUPUI, Team 2-4, Baechle Spring 2017 IUPUI, Team 2-4, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S2G4
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 572
