跳转到主内容
Dragon Touch M10X Power/Volume Button Replacement
你所需要的
  1. Dragon Touch M10X Power/Volume Button Replacement, Power/Volume Button: 步骤 1 中的图像 1,2 Dragon Touch M10X Power/Volume Button Replacement, Power/Volume Button: 步骤 1 中的图像 2,2
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Power/Volume Button Replacement: 步骤 2 中的图像 1,2 Dragon Touch M10X Power/Volume Button Replacement: 步骤 2 中的图像 2,2
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Power/Volume Button Replacement: 步骤 3 中的图像 1,2 Dragon Touch M10X Power/Volume Button Replacement: 步骤 3 中的图像 2,2
    • Ensure your buttons look like this
    • If either the buttons or the button holes in the back cover are dirty, clean them.
    • If the buttons are cracked or broken, they will have to be replaced
  4. Dragon Touch M10X Power/Volume Button Replacement: 步骤 4 中的图像 1,1
    • With the old buttons removed place the new ones in
  5. Dragon Touch M10X Power/Volume Button Replacement: 步骤 5 中的图像 1,1
    • These buttons are held in by gravity alone so when reattaching the device back on to the cover, keep it upside down.
    • Secure the bottom of the device first before closing up the sides.
结论
2等其他人完成本指南。
Eric Megna
于03/24/16注册
327 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 1,716
