跳转到主内容
Dragon Touch M10X Camera Replacement
你所需要的
  1. Dragon Touch M10X Camera Replacement, Camera: 步骤 1 中的图像 1,2 Dragon Touch M10X Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Camera Replacement: 步骤 2 中的图像 1,1
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Camera Replacement: 步骤 3 中的图像 1,2 Dragon Touch M10X Camera Replacement: 步骤 3 中的图像 2,2
    • Using your hands and the separating tool, remove the back cover from the device.
  4. Dragon Touch M10X Camera Replacement: 步骤 4 中的图像 1,1
    • Using a J0 phillips head bit, remove the single 1 mm screw from the rear facing lens cover.
  5. Dragon Touch M10X Camera Replacement: 步骤 5 中的图像 1,1
    • Using a J0 phillips head bit, remove the single 1mm screw from the front facing camera lens cover.
  6. Dragon Touch M10X Camera Replacement: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, pry the rear facing camera out of its housing.
  7. Dragon Touch M10X Camera Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using a plastic opening tool, lift up the latch that attaches the camera's ribbon cable to the device.
    • Using tweezers, pull out the ribbon cable from underneath the latch.
  8. Dragon Touch M10X Camera Replacement: 步骤 8 中的图像 1,1
    • Remove the camera strip from the device.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 376
