跳转到主内容
Dopo Double Power 7 Speaker Replacement
你所需要的
  1. Dopo Double Power 7 Speaker Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Speaker Replacement: 步骤 2 中的图像 1,1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Speaker Replacement: 步骤 3 中的图像 1,1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Speaker Replacement: 步骤 4 中的图像 1,1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
结论
另外一个人完成了本指南。
mike pelosi
于10/30/15注册
682 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 190
