跳转到主内容
加入维修社区 - 创建账户
Dopo Double Power 7 Digitizer Replacement
你所需要的
    1. Dopo Double Power 7 Digitizer Replacement, Rear Panel: 步骤 1 中的图像 1,1
      • The rear panel is secured to the front case and can simply be pried apart without damage.
      询问修复机器人
      添加评论
    2. Dopo Double Power 7 Digitizer Replacement: 步骤 2 中的图像 1,1
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
      询问修复机器人
      添加评论
    3. Dopo Double Power 7 Digitizer Replacement: 步骤 3 中的图像 1,1
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
      询问修复机器人
      添加评论
    4. Dopo Double Power 7 Digitizer Replacement: 步骤 4 中的图像 1,1
      • The rear panel should come completely off.
      询问修复机器人
      添加评论
    1. Dopo Double Power 7 Digitizer Replacement, Camera: 步骤 5 中的图像 1,1
      • Remove any black static tape that may be covering the motherboard.
      询问修复机器人
      添加评论
    2. Dopo Double Power 7 Digitizer Replacement: 步骤 6 中的图像 1,2 Dopo Double Power 7 Digitizer Replacement: 步骤 6 中的图像 2,2
      • The camera is taped in place.
      • Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
      • Our cable had previously been cut but yours can be disconnected by lifting up on the black section of the socket, as shown by the arrow, and pulling the cable out.
      • Simply, pull back the tape and remove the camera.
      询问修复机器人
      添加评论
    1. Dopo Double Power 7 Digitizer Replacement, Digitizer: 步骤 7 中的图像 1,2 Dopo Double Power 7 Digitizer Replacement, Digitizer: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a Phillips Head Screwdriver size 0.
      • Remove the four screws holding the motherboard inplace.
      • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
      • The cables can be disconnected by lifting up on the black section of the socket.
      • Once the lever is lifted, pull out the cable by gently tugging on it.
      询问修复机器人
      添加评论
    2. Dopo Double Power 7 Digitizer Replacement: 步骤 8 中的图像 1,1
      • Using wire cutters, cut only the gray wire.
      询问修复机器人
      添加评论
    3. Dopo Double Power 7 Digitizer Replacement: 步骤 9 中的图像 1,1
      • Using a metal spudger, carefully pry the battery away from the digitizer.
      • Be careful not to damage the battery.
      • At this point, the battery and the motherboard will still be connected although it is not shown in the image.
      询问修复机器人
      添加评论
    4. Dopo Double Power 7 Digitizer Replacement: 步骤 10 中的图像 1,1
      • The back of the digitizer is attached along the edge by 12 plastic clips.
      询问修复机器人
      添加评论
    5. Dopo Double Power 7 Digitizer Replacement: 步骤 11 中的图像 1,1
      • The best way to remove the digitizer is to use a plastic tool and pull back the clips so that it can lift out.
      • Be gentle and be sure not to break any of the clips.
      询问修复机器人
      添加评论
    6. Dopo Double Power 7 Digitizer Replacement: 步骤 12 中的图像 1,2 Dopo Double Power 7 Digitizer Replacement: 步骤 12 中的图像 2,2
      • The digitizer can now be removed and replaced.
      询问修复机器人
      添加评论
    7. Dopo Double Power 7 Digitizer Replacement: 步骤 13 中的图像 1,2 Dopo Double Power 7 Digitizer Replacement: 步骤 13 中的图像 2,2
      • Soldering will be required to connect the new digitizer.
      • Any remaining wire left from the old digitizer will need to be removed from the motherboard.
      • Take care not to burn yourself or damage the motherboard, wires, or new digitizer while soldering.
      • Solder the new digitizer to the soldering point shown within the image.
      • Using wire strippers, strip the end of the gray wire connected to the new digitizer about a 1/8".
      • Solder the gray wire to the soldering point on the motherboard as shown within the image.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
mike pelosi
于10/30/15注册
682 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 897
