跳转到主内容
加入维修社区 - 创建账户
Dopo Double Power 7 Battery Replacement
你所需要的
    1. Dopo Double Power 7 Battery Replacement, Rear Panel: 步骤 1 中的图像 1,1
      • The rear panel is secured to the front case and can simply be pried apart without damage.
      询问修复机器人
      添加评论
    2. Dopo Double Power 7 Battery Replacement: 步骤 2 中的图像 1,1
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
      询问修复机器人
      添加评论
    3. Dopo Double Power 7 Battery Replacement: 步骤 3 中的图像 1,1
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
      询问修复机器人
      添加评论
    4. Dopo Double Power 7 Battery Replacement: 步骤 4 中的图像 1,1
      • The rear panel should come completely off.
      询问修复机器人
      添加评论
    1. Dopo Double Power 7 Battery Replacement, Battery: 步骤 5 中的图像 1,1
      • Cut only the red and black wires attaching the battery to the motherboard.
      • Be sure to remove any remaining wire attached to the motherboard.
      询问修复机器人
      添加评论
    2. Dopo Double Power 7 Battery Replacement: 步骤 6 中的图像 1,1
      • Using a metal spudger, carefully pry the battery away from the digitizer.
      • Be careful to not damage the battery. This could result in injury.
      询问修复机器人
      添加评论
    3. Dopo Double Power 7 Battery Replacement: 步骤 7 中的图像 1,1
      • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
      • Twist the strands of the spliced wire together.
      • Using a soldering iron, apply heat to one bare wire connections you have just made.
      • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
      • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
      • Repeat this process with the other wire.
      • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
      • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
mike pelosi
于10/30/15注册
682 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G2
4 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,348
