跳转到主内容
加入维修社区 - 创建账户
Doorknob Privacy Pin Replacement
你所需要的
  1. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: 步骤 1 中的图像 1,3 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: 步骤 1 中的图像 2,3 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two screws holding the interior and exterior doorknob halves together.
  2. Doorknob Privacy Pin Replacement: 步骤 2 中的图像 1,2 Doorknob Privacy Pin Replacement: 步骤 2 中的图像 2,2
    • Carefully pull the doorknob halves apart.
    • The spindle and the latch mechanism should now be accessible.
  3. Doorknob Privacy Pin Replacement: 步骤 3 中的图像 1,3 Doorknob Privacy Pin Replacement: 步骤 3 中的图像 2,3 Doorknob Privacy Pin Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the privacy pin.
    • It is a small, threaded pin that screws into a hole on the latch mechanism itself or on the interior doorknob assembly.
  4. Doorknob Privacy Pin Replacement: 步骤 4 中的图像 1,1
    • Remove the old/ damaged privacy pin.
  5. Doorknob Privacy Pin Replacement: 步骤 5 中的图像 1,3 Doorknob Privacy Pin Replacement: 步骤 5 中的图像 2,3 Doorknob Privacy Pin Replacement: 步骤 5 中的图像 3,3
    • Screw the new privacy pin into the corresponding hole.
    • Ensure it's securely tightened but don't overtighten, as this could strip the threads.
  6. Doorknob Privacy Pin Replacement: 步骤 6 中的图像 1,3 Doorknob Privacy Pin Replacement: 步骤 6 中的图像 2,3 Doorknob Privacy Pin Replacement: 步骤 6 中的图像 3,3
    • Align the spindle with the latch mechanism, then bring the two doorknob halves back together.
    • Make sure all parts are properly seated.
  7. Doorknob Privacy Pin Replacement: 步骤 7 中的图像 1,3 Doorknob Privacy Pin Replacement: 步骤 7 中的图像 2,3 Doorknob Privacy Pin Replacement: 步骤 7 中的图像 3,3
    • Securely fasten the two screws with the Phillips #1 screwdriver.
    • Snap or twist the decorative covers back into place (If applicable).
    • Test the privacy pin several times to ensure it engages and disengages smoothly.
结论
Elias Moseri
于06/15/25注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 41
总计 277
