简介
Whether your doorknob's privacy pin is broken, stuck, or simply missing, replacing it is a common home maintenance task that can restore security and functionality to your door.
This guide will quickly walk you through the simple steps to swap out that old pin for a new one. All you need is a screwdriver and a new door privacy pin.
你所需要的
Use a Phillips #1 screwdriver to remove the two screws holding the interior and exterior doorknob halves together.
结论
