简介
Doors are a major part of our lives, and we use them on a day-to-day basis. Some problems may occur with constant use and age, which can be solved with an extremely quick fix by replacing the door’s old hinge with a new one.
If your door is having problems opening and closing, it may be because of your old door hinge being damaged due to age and general wear-and-tear.
Before proceeding with this guide, you must know how to use a screwdriver and tape measure.
Step 2 requires you to secure the door to prevent it from falling over while you’re replacing the old hinge. Take extra precaution to prevent the door from falling over
你所需要的
Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
另外一个人完成了本指南。
