跳转到主内容
加入维修社区 - 创建账户
Door Hinge Replacement
你所需要的
  1. Door Hinge Replacement, Hinge: 步骤 1 中的图像 1,2 Door Hinge Replacement, Hinge: 步骤 1 中的图像 2,2
    • Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
  2. Door Hinge Replacement: 步骤 2 中的图像 1,2 Door Hinge Replacement: 步骤 2 中的图像 2,2
    • Use two sturdy pieces of wood or cardboard that can keep the door in place and put them underneath the door.
    • Make sure that the door isn’t slanted or tilted to make it easier to replace the new door hinge.
  3. Door Hinge Replacement: 步骤 3 中的图像 1,2 Door Hinge Replacement: 步骤 3 中的图像 2,2
    • Remove the three screws from the hinge that are connected to the door by using a Phillips 1 screwdriver.
    • Remove the three screws from the hinge that are connected to the door frame using a Phillips #1 screwdriver.
  4. Door Hinge Replacement: 步骤 4 中的图像 1,2 Door Hinge Replacement: 步骤 4 中的图像 2,2
    • Repeat Step 3 with the bottom hinge on the door.
  5. Door Hinge Replacement: 步骤 5 中的图像 1,2 Door Hinge Replacement: 步骤 5 中的图像 2,2
    • Rub sandpaper on the areas where the new hinges will be.
    • This makes sure that splinters or any wood debris from both the frame and the door will be removed.
  6. Door Hinge Replacement: 步骤 6 中的图像 1,2 Door Hinge Replacement: 步骤 6 中的图像 2,2
    • When replacing your new door hinge, make sure that the hinge that is facing towards you can be fully closed
  7. Door Hinge Replacement: 步骤 7 中的图像 1,3 Door Hinge Replacement: 步骤 7 中的图像 2,3 Door Hinge Replacement: 步骤 7 中的图像 3,3
    • Align the new door hinge with the screw holes in the frame and screw in the new door hinge in the frame.
    • Repeat this with the bottom area of the door.
  8. Door Hinge Replacement: 步骤 8 中的图像 1,3 Door Hinge Replacement: 步骤 8 中的图像 2,3 Door Hinge Replacement: 步骤 8 中的图像 3,3
    • Align the new door hinge with the screw holes in the door and screw in the new door hinge.
  9. Door Hinge Replacement: 步骤 9 中的图像 1,2 Door Hinge Replacement: 步骤 9 中的图像 2,2
    • Spray a small amount of WD-40 at the back top and bottom hinge and wipe it down with an old rag.
终点
另外一个人完成了本指南。
Zeniff Aviles
于01/19/21注册
234 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 38
总计 1,068
