跳转到主内容
Door Frame Strike Plate Replacement
你所需要的
  1. Door Frame Strike Plate Replacement, Strike Plate: 步骤 1 中的图像 1,1
    • With a screwdriver, remove the two screws holding the strike plate in place.
    • The screwdriver used during this guide will vary due to the size of the pre-existing screws.
  2. Door Frame Strike Plate Replacement: 步骤 2 中的图像 1,1
    • Remove the damaged strike plate from the door frame.
    • Depending on the type of strike plate, the strike plate may not remain in place after removing both of the screws.
  3. Door Frame Strike Plate Replacement: 步骤 3 中的图像 1,1
    • Replace the damaged strike plate with a new strike plate.
    • The holes of the new strike plate should align with the holes of the damaged strike plate. If they do not, new holes on the door frame would need to be drilled.
  4. Door Frame Strike Plate Replacement: 步骤 4 中的图像 1,1
    • Apply the new strike plate to the frame of the door, and ensure that the strike plate's holes are aligned with the drilled-in holes on the door frame.
  5. Door Frame Strike Plate Replacement: 步骤 5 中的图像 1,1
    • Screw in the top screw first, ensuring that the strike plate will remain in place. Then, screw in the bottom screw.
  6. Door Frame Strike Plate Replacement: 步骤 6 中的图像 1,1
    • Ensure that the strike plate is not loose by trying to wiggle the strike plate with your hand.
    • If the strike plate budges, continue screwing in the screws until it does not budge.
终点
一条评论
How do I fill the old hole as my new plate does not line up ?
DeniseB - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 105
总计 4,993
