跳转到主内容
Dispenser Disconnection (Prereq)
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Dispenser Disconnection (Prereq), Disconnect the control panel: 步骤 1 中的图像 1,3 Dispenser Disconnection (Prereq), Disconnect the control panel: 步骤 1 中的图像 2,3 Dispenser Disconnection (Prereq), Disconnect the control panel: 步骤 1 中的图像 3,3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  2. Dispenser Disconnection (Prereq), Unclip the control panel cable: 步骤 2 中的图像 1,3 Dispenser Disconnection (Prereq), Unclip the control panel cable: 步骤 2 中的图像 2,3 Dispenser Disconnection (Prereq), Unclip the control panel cable: 步骤 2 中的图像 3,3
    • Unclip any connections the control panel cable has to the chassis or other components.
  3. Dispenser Disconnection (Prereq), Detergent dispenser hose information: 步骤 3 中的图像 1,1
    • To prevent confusion, label each detergent hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  4. Dispenser Disconnection (Prereq): 步骤 4 中的图像 1,2 Dispenser Disconnection (Prereq): 步骤 4 中的图像 2,2
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  5. Dispenser Disconnection (Prereq): 步骤 5 中的图像 1,2 Dispenser Disconnection (Prereq): 步骤 5 中的图像 2,2
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  6. Dispenser Disconnection (Prereq): 步骤 6 中的图像 1,2 Dispenser Disconnection (Prereq): 步骤 6 中的图像 2,2
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  7. Dispenser Disconnection (Prereq), Disconnect the dispenser: 步骤 7 中的图像 1,3 Dispenser Disconnection (Prereq), Disconnect the dispenser: 步骤 7 中的图像 2,3 Dispenser Disconnection (Prereq), Disconnect the dispenser: 步骤 7 中的图像 3,3
    • Loosen any fasteners securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
结论
Bill Gilbert
于06/30/22注册
38,555 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 45
