你所需要的
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
Pull the detergent drawer away from the chassis as far as it will go.
Use your hands to unclip the control panel cable from the detergent dispenser.
Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
Compress the clip and slide it out of the chassis to remove it.
Move the cables out of the way of the detergent dispenser hoses before you continue.
To prevent confusion, label each hose and its corresponding dispenser connection.
Use a Phillips driver to loosen the screw securing the bellows to the detergent dispenser.
Pull the bellows straight off its connection on the dispenser to disconnect it.
