跳转到主内容
Disney Netpal RAM Replacement
你所需要的
  1. Disney Netpal RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Disconnect the power cable, turn the netbook upside down and locate the panel that is marked with a little "DDR" icon.
    • Remove the two screws that keep it in place. They don't have to come out entirely and tend to stay with the panel.
    • Lift the panel out. While you should make sure that the screws are disconnected from the base, this may take some force as the panel has two additional clickety bits.
  2. Disney Netpal RAM Replacement: 步骤 2 中的图像 1,3 Disney Netpal RAM Replacement: 步骤 2 中的图像 2,3 Disney Netpal RAM Replacement: 步骤 2 中的图像 3,3
    • The RAM is now exposed.
    • Push the two metal clamps on the sides outwards. The DIMM flips up. If it doesn't, be very careful about forcing anything - you're working with tiny and fairly vulnerably tech here.
    • To remove the memory, grip it by the sides - do not touch the flat part with any kind of force - and pull it out in the direction it's pointing.
    • Take the new stick and place it in the same diagonal position. Verify that it is in the socket all the way and properly aligned.
    • Push it down - again by holding the sides as much as possible - until the clamps audibly click shut.
    • Make sure the clamps snugly fit into the notches on the side of the DIMM. If this isn't the case the stick is probably not inserted all the way, so carefully take it out again, check the slot for dirt or other obstructions and retry.
    • To close up, put the access panel back in place: the side without screwholes goes first.
    • Push it down a little to hear the plastic clicky bits slot into place and tighten the screws.
结论
Everything should now be fine. If anything at all has gone wrong you'll find out when the netbook refuses to boot - the power LED will go on, the hard drive LED might blink once or twice but then nothing happens. If this happens to you, go back and check whether everything is snug and tight as it should be.
2等其他人完成本指南。
Minic
于07/13/10注册
321 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 1,537
