跳转到主内容
加入维修社区 - 创建账户
Disconnecting the Battery
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Disconnecting the Battery, Bottom Cover: 步骤 1 中的图像 1,2 Disconnecting the Battery, Bottom Cover: 步骤 1 中的图像 2,2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Disconnecting the Battery: 步骤 2 中的图像 1,3 Disconnecting the Battery: 步骤 2 中的图像 2,3 Disconnecting the Battery: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Disconnecting the Battery, Disconnecting the Battery: 步骤 3 中的图像 1,3 Disconnecting the Battery, Disconnecting the Battery: 步骤 3 中的图像 2,3 Disconnecting the Battery, Disconnecting the Battery: 步骤 3 中的图像 3,3
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Disconnecting the Battery: 步骤 4 中的图像 1,2 Disconnecting the Battery: 步骤 4 中的图像 2,2
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 89
